Subject: Re: Source for solid door cores in Pac NW
9/28/22
Willis B
I'm building a flush entry door with a 21" dia. circular window. I'd like to use either a strand core or a stave core, but I haven't been able to find a supplier, let alone one that would sell me just one core. I can make my own stave core but buying one would sure save me some time. Any help?
10/3/22       #2: Source for solid door cores in Pac ...
gary
I would steer clear of any LVL core for exterior use as it doesn't play well with moisture. I would build as a type of ladder and put foam in the voids. That way you can block out for the window. Then a layer of substraight on each side that sits flush to your edge band and then your finish veneer as a final layer. I typically make my own veneer at 3/16" thick and after widebelt it finishes at a thick 1/8" . You can control all your glue choices at every stage of fabrication instead of relying on someone else.
10/4/22       #3: Source for solid door cores in Pac ...
Willis B
Found a relatively local source for pine or fir stave core, so LVL is already crossed off the list. Ladder frame sounds like a good idea, but a lot more work compared to buying or even building a stave core. On the other hand, now I'm concerned the stave core may bow across the top edge (where a rail would be). The circle cutout is 7" from the top. What type of substrate would you use for the ladder frame?
10/4/22       #4: Source for solid door cores in Pac ...
gary
Be sure to "Cross-Sight" the door when you glue together your ladder. I use two four foot levels placed on each end of the door. Get back about 14' and sight across the top of one level to the top of the other level to make sure they are parallel with each other. That will ensure a flat, non-twisted door after the glue sets up. Just a larger version of winding sticks.
    Doucet Machinery
