Subject: Re: Which shoe molding use in my kitchen cabinet
10/11/22
Willie Osgood Member
Hi, I am a newbie. Need suggestions about shoe molding. Which type of shoe molding is better for kitchen cabinets? Can I use PVC shoe molding?
6 Types of Shoe Molding
10/11/22       #2: Which shoe molding use in my kitche ...
A newbie professional, or a newbie hobbyist?
10/11/22       #3: Which shoe molding use in my kitche ...
New or not, professional or amateur, what kind of question is that? Plastic moldings absolutely have no place in the quality work Woodweb members produce. Most would agree that MDF has no place in better work. Solid wood is what is used in better work.
Now, I went thru the trouble to answer your question. I even clicked on the laughable link to Willy-land. I will now ask you to return the favor and tell us the situation you are in - pro or amateur? You built the cabinetry, or just ended up here as a result of searches?
10/11/22       #4: Which shoe molding use in my kitche ...
BH Davis  Member
Willie seems to not know the difference between shoe moulding and base cap.
BH
10/17/22       #5: Which shoe molding use in my kitche ...
Jim Herron
Those two minutes are gone forever....
11/4/22       #6: Which shoe molding use in my kitche ...
Kevin Dunphy
Website: http://kdunphy.com
LOL [at the response] need to do your research before asking a question
But this brings up the topic housing market is 90 percent mdf and the other percent is painted mouldings . I think someone starting needs to separate them selfs from the pack when I say 90 percent add another 8 percent that could not install natural wood Mahoney, oak, etc as moldings, casing, panels etc, lost skill
I think the hobbyist has to stop copying the Ikeas and working with MDF. I would welcome a hobbyist if they brought something new I love to learn
Last I will shamelessly plug a video I did on wood paneling
https://www.youtube.com/watch?v=wB_PNZVv3WQ&t=17s
1/14/23       #7: Which shoe molding use in my kitche ...
D CONTI
Once again "no woodweb user would use mdf" Pure an utter BS. MDF has uses just like any other product. Architects have been spec'd mdf for years, and these are people with a lot of education in their past. I am proud to say I am woodweb user (for years) a wood worker with 30 years experience and an avid mdf user. I wish to ask my friend here at wood web why is it that the best grade veneer panel products are always on mdf core? Try to get booked walnut squenced matched on veneer core, and it will be a special order item. "if it aint wood it anit real" went out with leaded gasoline. There are plenty of high end projects out there with mdf substraints. I am going to tell you something you will not like, just try to get a sheet of domestic plywood like the type that was produced in the 1970's. It just is not going to happen, the core was a good solid void free wood, the hardwood veneer was 1/16 " thick. It layed flat and stayed flat. The domestic stuff we get today would have been rejected by 90 % of the shops back then as shop or worse grade. Times have changed, solid wood is not what it used to be, and Kennedy is no longer president. You either adapt to change or you are trapped in the past. Just remember our grand father, and their grandfather always said "those good old days" and when we get old we will say the same thing. You must evolve with the times or be however better about change.
    Doucet Machinery
