Subject: Re: Thickness sanding MDF?
11/26/22
Mark Member
I have never had a need for an odd ball thickness of MDF bit I am matching a vintage piece and need the MDF about a heavy 5/8” possibly 11/16”. I have 3/4” on hand and a wide belt of i sand it to thickness will I encounter issues with warp/twist? Is the density different if i wide belt that will affect anything? I will be using commercial raw veneer.
Also it’s been a long time since I put solid edging on first then veneered with commercial veneer (i typically use thicker shop sawn) over top of solid banding, i will be using commercial flatsawn Walnut over 1/4” solid walnut, will i get telegraphing of the solid?
11/26/22       #3: Thickness sanding MDF? ...
Mark B
RE the MDF Ive definitely seen issues if your just removing one face of the MDF but in my experience it depends on the material. Double refined is more stable and would be more consistent from the face through the core. Straight brown paper bag MDF in my experience can tend to move a lot of you heavily machine or remove one face leaving the opposing face with the factory smooth. The straight MDF with both faces removed is pretty much junk at that point in my opinion but if you get it veneered I suppose it'd be fine.
11/26/22       #4: Thickness sanding MDF? ...
david
Definitely sand both sides of the MDF, and you will want to use a crossband with grain running opposite of the face. This should help with the solid wood telegraphing.
11/26/22       #5: Thickness sanding MDF? ...
In a previous shop we edged with 1/4" under veneer then hot pressed with UF glue. We did have telegraphing of the edges. In my shop first with a vacuum press then with a hot press but heating only to 50-60° C I haven't seen telegraphing. We may have been levelling the edges too fast after gluing previously.
11/28/22       #6: Thickness sanding MDF? ...
BH Davis  Member
I did a 3D surface carving on a 36" x 48" x 3/4" piece of MDF years ago without relieving the back. The thing turned into a saucer with about a 1/2" deflection from center to the edges all the way around. I redid the project after first removing 1/16" off the back and the 2nd one came out perfectly flat.
