Subject: Re: finger joint cutter
finger joint cutter
11/29/22
Mark Member
Looking for a finger joint cutter for my 1-1/4" spindle shaper that will handle 2-1/4" thick material for the occasional radial door head rail. Not having any luck surfing.
Thanks,
Mark
11/30/22       #2: finger joint cutter ...
https://woodtechtooling.net/
Search for finger joint and look at Stark. We have run one of these heads for years.
Good Luck
11/30/22       #3: finger joint cutter ...
Mark B
I dont have any input on the finger joint cutter but we bought a stark small shop cabinet insert head from them years back and loved it but they seem to have abandoned the US market and we are now stuck with basically $2k worth of brick where the head will likely go in the aluminum scrap pile to bring less than a dollar of return. I reached out to stark overseas EU/UK with zero response. Unless Im missing a solution I would never give Stark a dollar of my money again.
11/30/22       #4: finger joint cutter ...
Hen Bob Member
Did you try Rangate? Lietz?
11/30/22       #5: finger joint cutter ...
Joe Calhoon Member
I’ve used a Garniga adjustable end grain finger joint cutter for 20 years. Thickness range is from 14 mm to 96mm.
The Zuani one that Rangate sells is similar. The joint strength of these is pretty amazing. On a 68 mm thick segment there is about 5” of two sided long grain glue surface.
Mark, for Stark inserts have you tried AMS in the UK? I have bought other items from them and the service seems good. Also the Felder tooling is made by Stark. I have never had issues getting inserts from them. Specific to the cutters they sell though.
12/1/22       #6: finger joint cutter ...
Al
I can’t help you Mark but Joe that is some slick clamp in your last picture. Looks like you tighten the clamps on both sides of pieces than throw the lever to bring them together.
12/2/22       #7: finger joint cutter ...
Mark B
Joe,
It turns out Cogent Tooling is now the US distributor for Stark. Low an behold the insert heads I have were supposedly developed just for Woodtech in the US so we are now looking at custom grinds for replacement inserts.. Is what it is I guess. Caveat emptor.
12/2/22       #8: finger joint cutter ...
Why do you need custom grinds? Wood Tech is still there. I believe inserts are still available.
12/2/22       #9: finger joint cutter ...
Mark B
No, woodtech is gone.
12/3/22       #10: finger joint cutter ...
Website still works.
12/4/22       #11: finger joint cutter ...
Mark B
Yes the site is alive but when Chuck passed all changed. After Joes mention above I reached out to AMS UK and was directed to Cogent tooling as the US distributor for Stark then to find the heads we have were developed by start for woodtech specifically for the US market and inserts are now custom grinds. Is what it is.
12/4/22       #12: finger joint cutter ...
Joe Calhoon Member
Mark,
Hate to hear that about Woodtech. They were my go to for feed roller recovering on moulders and power feeds. They did a real nice job on that.
Al,
That’s exactly how this clamp works. I had a pneumatic arch press that I sold a while back in a downsizing move. This one works about as well.
View higher quality, full size image (2724 X 3632)
12/4/22       #13: finger joint cutter ...
Joe we use western roller for feeder/moulder wheels. They are very good.
