Subject: Re: Balusters angle cut
Balusters angle cut
3/19/23
Thomas
Website: http://artisancnc.com
We have a customer who is wanting us to turn 40-50 balusters for his porch. He sent the drawings and I noticed that the bottom notch was the full 5" dia. of the balusters bottom. Thought about cutting the notch prior to turning them, but then I have no way to hold them in the duplicator. Any ideas as to what would be the best method here? Thanks
3/19/23       #2: Balusters angle cut ...
Matt Calnen
Could you provide a drawing or sketch?
The title says angle cut, and the post says notch. I assume you mean what I call a saddle cut to go over a peaked lower rail. I table saw jig is how I do that. Round is adding a degree of complexity, but I imagine a line across on the top of the baluster butted into a stop that was half the diameter would work for reference.
3/19/23       #3: Balusters angle cut ...
Thomas
Matt,
I don't know how to send this type of a file on woodweb. Customer sent it to us on cell phone. In the morning I should be able to have the office mgr. is she can do this. In the meantime, The bottom rail is approx 6" wide and has a full 45 deg. cut, with the point going into the bottom of the spindle. If I cut the 45 deg (actually 90deg. included) then the point for the 90deg tip would be in the center of the spindle, coming up from the bottom rail. i just reread this and it does sound confusing. I will have the picture on here in the morning.
3/20/23       #4: Balusters angle cut ...
Thomas Member
Matt
Here is the drawing
3/20/23       #6: Balusters angle cut ...
Matt Calnen
45 degrees on a 6” turning is going to require a 12” blade.
With the narrow top, you will need to build a jig to hold the baluster level. Maybe something like this drawing. Extend the center line to the outside of the jig. Make a center line on the top of the turning and just line them up. If you’re careful it should be close enough. I assume these are paint grade?
3/20/23       #7: Balusters angle cut ...
Walter Member
I've done this on a table saw with jigs and stops. Paint grade is pretty easy; stain grade would obviously require a nice tight jig and extra care. In my opinion, that 45 degrees seems too steep. I'd lobby for a 15 or 22 degree slope (maybe 30 degrees if in a very wet climate). If you have any stairs to do, that's a bit more complex with a compound notch. But a jig is your friend. Definitely do a bunch of practice runs on scrap! There are some videos online.
3/20/23       #8: Balusters angle cut ...
Matt Calnen
3/20/23       #9: Balusters angle cut ...
Thomas
Matt,
Thanks for the drawing. I believe we can do this. Not sure if the customer will like our price.
Walter, thanks for the reply. It is paint grade, and I agree that 45 is too steep. Location Knoxville, TN. Pretty good climate here.
I
3/23/23       #10: Balusters angle cut ...
peter
Norm would stand them up and do it on the tablesaw w a sled.
    Doucet Machinery
