Subject: Re: Coping Sled
Coping Sled
4/12/23
Eric
Does anybody have experience with this coping sled. Or does anybody have recommendations for one. I need one that can fit 2.25" rails for exterior doors.
Thank you.
Coping Sled
4/28/23       #2: Coping Sled ...
It looks as if it will work fine. But if you have 8" wide cutter exposed, and a 13" wide rail you will need at least 17" travel, with 20" or so preferred. You should be able to fabricate a longer base plate. See McMaster-Carr.
5/6/23       #3: Coping Sled ...
AC
We have had real good luck with the Aigner Contermax
https://www.simantechinc.com/index.php?l=product_detail&p=89
5/6/23       #4: Coping Sled ...
I have a coping sled that registers along a continuous fence that runs under the cope heads. The sled is 3/8" aluminum plate, with two air clamps above, and a fence that accepts a wood backer. Can handle up to 13" width as well as muntin stock. It rides on UHMW straps. Fast, easy sold and safe. Also will accept up to 3" thick parts. Love it.
5/8/23       #5: Coping Sled ...
Pete
David,
Any chance you can post a pic of your sled?
5/9/23       #6: Coping Sled ...
Not the best shot, but you get the idea. The overhead aluminum bar holds the two air clamps and allows positioning where needed. The aluminum back up bar is concealed by the wood back up strip. It is fixed at 90 degrees so we would never have to go in and try to get back to absolute square. The heavy plate rides on two recessed UHMW strips, and registers against the fence.
12/9/23       #7: Coping Sled ...
Andrew S Ryals Member
Try Weaver
