Subject: Re: HINGE BORING MACHINE
3/20/24
Gary
I need to drill a 3/16'' hole every 16'' in a piece of hot rolled steel that is 3/8 x 1-1/2''. So I'm drilling through 3/8'' steel. 20 to 30 pieces or so at a time. Instead of doing it on the drill press I am wondering if I could have a bit made to fit a Blum or Grass hinge boring machine ? Assuming the feed speed is adjustable I could slow it down a bit etc. Please let me know what y'all think.
Thank you
3/21/24       #2: HINGE BORING MACHINE ...
Ryan Torok Member
I would avoid trying that, the drill speed on a minipress is too fast for drilling steel. Even though you could slow the speed down in which it progresses the cut, the RPM on the drill bit would be too fast, especially for 3/8 steel.
3/21/24       #3: HINGE BORING MACHINE ...
Rich  Member
We recently used an electric hydraulic punch to make holes in thinner steel. but there are similar units for thicker steel take a look this might be a real time saver. We punched several hundred holes in a couple of hours.
Hydraulic Punch
3/22/24       #4: HINGE BORING MACHINE ...
Have a laser company do it. Should take about 1 hour.
3/24/24       #5: HINGE BORING MACHINE ...
Jim Herron
Have it punched at your local steel yard
Should take just a few minutes
3/26/24       #6: HINGE BORING MACHINE ...
I agree with Rich. Laser it out, done. You're gonna burn $1000 in time for $200 of work
3/26/24       #7: HINGE BORING MACHINE ...
Jim Herron
Agreed on the laser.
Sorry, I thought you were punching 3/8" holes
4/2/24       #8: HINGE BORING MACHINE ...
Steve Member
Website: https://virmer.com/
I wouldn't recommend that, you may cause much more damage
    Doucet Machinery
