Subject: Re: Rabbeted Jambs
Rabbeted Jambs
5/16/24
Gary
It seems like the proper way ( although more time consuming?) to produce rabbeted jambs would be to spline together, for example, a 1'' thick piece of wood to a 1-1/2" thick piece of wood to net a 1/2'' step/rabbeted jamb. Thereby avoiding any cupping that may occur when rabbeting out the 1/2" of material from a solid piece. The 1'' thick wood could be finished sand before gluing it. The 1-1/2" could be notched for the heads before gluing as well.
Any thoughts ?
Thank you, Gary
5/20/24       #2: Rabbeted Jambs ...
Fred
Website: http://www.rivercity.ca
HI Gary,
We do build our exterior jambs up as a 2 part unit. For deeper jambs sometimes even 3. This gives you the option to offset your corners as well.
the attached picture is just a mock up but it should explain.
6/10/24       #3: Rabbeted Jambs ...
There are two ways to work wood. One is additive, where smaller pcs are assembled to make a part. The other is subtraction, where wood is removed to make a part. Subtraction is the preferred method for architectural work. You handle one part in place of 2 or 3. Anytime you can reduce part counts you are ahead o ,f the
game.
7/16/24       #4: Rabbeted Jambs ...
John Bishop  Member
I agree with David R. Did a lot of doors. It is not that hard to remove the stock in a typical split rail jamb. A normal dado head can do this quickly, then some detail work to clean it up. If you are doing a bunch you might consider someone with a molder to farm out that bit.
DJB
