Subject: Re: Outdoor Plywood 1979 Condo Breezeway
6/22/24
Lumber Jayne
Our 1979 condo complex has breeze ways and the T90 (I think that’s what it is called) wall paneling, painted aluminum railing system, baseboards, and old commercial carpet. The breezeways get filthy because we are located in a busy street. It not easy to just wipe down because of the older paint is chalky and T90 wall coverings panels has groves and pimply texture and we are located in F, all floors seem solid but one panel does feel deteriorated at the end of the breezeway of one out of the 5 buildings.
My question is can we powerwas the baseboards, aluminum painted railing and banister, where so much dirt gets hung up a the wall with the T90 panels? One lady keeps thinking we’re going to ruin the wood subflooring under the carpet when I think that it’s probably Marine ply and once a year, it’s not going to damage it because we’re in Florida and it’s a breezeway that gets rain and I imagine that back in 1979 they thought of this when they put down the plywood and had city codes to follow. What are your thoughts?
View higher quality, full size image (960 X 2079)
6/22/24       #2: Outdoor Plywood 1979 Condo Breezewa ...
Hen Bob
My best advice would be to contact you local city zoning board , powerwashing can lead to many unforeseen health risks
6/23/24       #3: Outdoor Plywood 1979 Condo Breezewa ...
BH Davis  Member
I've never heard of T90 siding. Masonite siding is sometimes referred to as X90 but that is typically horizontal clapboards. My guess, from the description and photos is that you have T1-11 siding. That is plywood siding that comes with a vertical board pattern with about 3/8" gaps between 6" to 8" wide boards (in appearance).
I'd not be at all concerned about power washing anything in the photos. The only issue I've seen with power washing is on buildings from the 1960's and earlier that might have lead paint. In that case the power washer can, and likely will, strip off paint chips. That brings the project into a whole new world of federal regulations and guidelines.
So as long as the building is not older than the mid-60s you should have no negative issues with power washing once a year.
8/5/24       #5: Outdoor Plywood 1979 Condo Breezewa ...
oliverosalie Member
Power washing the baseboards, painted aluminum railing, and T90 wall panels could help with cleaning, but be cautious. While the subflooring is likely marine ply designed for durability, excessive moisture from power washing could still cause issues. It’s wise to test a small area first and ensure proper drying afterward. If there’s concern about damaging the subfloor, consider alternative cleaning methods or consult a professional.
