Subject: Re: edge bander issues
edge bander issues
6/30/24
Roger N Williams Member
Hi, I have a 2018 SCM me 40 edge bander. I use it very little and when I went to run it today, I could not get the control panel to come on at all. I have correct voltage to the machine as I checked all of that. I have correct voltage coming out of main switch. All lights are lit inside machine, but I am not getting anything to come on at main computer screen. All Estops are properly disengaged, the lid safety switch is properly engaged.
Can anyone tell me what might cause the main control panel to not be energized?
7/3/24       #3: edge bander issues ...
Jamie Hughes
My griggio did something similar a few years back, it was the air pressure sensor. Mine was an electro-pnumatic valve that was stuck.
7/3/24       #4: edge bander issues ...
Thanks so much for response Jamie. Did your computer screen not light up at all? Typically, on these machines with a PLC all the error codes will come up on the screen but the screen itself just seems to have no power.
Anyone else out there that has had this issue especially on an SCM machine??
