Subject: Re: Engineered Planks
Engineered Planks
12/15/24
Gary
I am going to be laminating a lot of 'Planks' of white oak for flat interior door panels. They will be approx 80'' long by 5'' wide by 1'' thick by laminating 1/8'' veneer on both sides of 3/4'' Medite/MDF. Then they will be splined/glued to each other to make panels. Does anyone see a problem with the Medite and if so can you recommend a better core material ?
12/16/24       #2: Engineered Planks ...
tom gardiner
If you are using a water-based glue the oak laminates might want to curl. Eighth inch veneer can exert quite a bit of force as compared to thinner veneers. It might pull the mdf apart.
I'm not a fan of thick veneers beyond 1/16". You can buy excellent 1/16" veneer from certainlywood.com and save the resawing and sanding hassle.
12/17/24       #3: Engineered Planks ...
tom gardiner
One more thing. Do some samples. If there is a risk of the veneers pulling away from the substrate it will happen in the first 24 hours.
12/17/24       #4: Engineered Planks ...
Dave Sochar Member
Seems like a lot of work for negligible gain. Perhaps there is a certain look you want.
I would buy some 3/4” MDF and 1/16” veneer, and layup the panels as 3 pcs each. Far fewer pieces to handle.
6/13/25       #5: Engineered Planks ...
Monica Chou Member
Website: https://www.zonledoors.com/
Medite (medium density fiberboard, MDF) is a common core material for laminated interior door panels. It has the advantages of high flatness, good stability and easy processing. However, there are a few points to note:
1. Poor moisture resistance: Medite is not resistant to moisture and is easy to absorb moisture and expand, so it is not suitable for humid environments or bathroom doors.
2. Weak nail holding force: If the door needs to be installed with hardware, the screw fixing force is not as good as plywood.
3. Heavy weight: It is heavier than plywood and has requirements for hinge load-bearing.
If a better core material is needed, it is recommended to use softwood core plywood (such as soft poplar plywood) or Paulownia multilayer board, which have:
1. Better structural strength
2. Better moisture resistance
3. Lighter, suitable for large-size door panels
If the budget allows, you can also choose moisture-resistant MDF (MR MDF) to improve moisture resistance while maintaining surface flatness.
Summary: Medite can be used, but high-quality plywood core materials are more recommended to improve durability and structural stability.
