Subject: Re: Mortise machine straight chisel
2/3/25
Al
Not sure if this exists or not. 3/4” chisel that would fit into mortise machine. It would just be making a shear cut, no drill bit. I want to use it for beaded face frames for the square part. I tried a regular 4 sided mortise chisel and it works but I think a flat chisel would work better.
Thanks,
Al
2/3/25       #2: Mortise machine straight chisel ...
Dave Sochar Member
Use a 3/4” mortise chisel that is ground back on 3 sides, leaving one blade protruding.
I have seen frame choppers do that cut for the flat and both miters. Ultra clean, quiet and fast. Hoffman ? Was the maker. Machines were foot operated, made mostly for picture frame cutting.
Or, a router bit and standing up a gang of stiles on edge and getting several in one pass with a custom bit. The cuts had to be roughed first, on tablesaw with a dado.
2/3/25       #3: Mortise machine straight chisel ...
Al
The Morso picture frame machine is what I have in mind. 2 notches that go in and hit the shoulder behind the bead and then mortise machine to shear off the remaining inside. I know guys just use a chisel but with the mortise machine you are going down nice and straight.
