Subject: Re: Thermally Modified Wood
12/1/24
Fred Member
Website: http://www.rivercity.ca
Hi,
Did anybody build exterior doors with Thermally Modified Wood?
Specifically Ayous or Korina?
We have used Accoya with good results for paint grade but it does not have very nice grain and that makes it less desirable for a stain grade product.
Looking for any info good or bad.
Thank you,
Fred
12/1/24       #2: Thermally Modified Wood ...
I had to finish a thermally modified wood door. I think it was mahogany. So I stained it and put a 2K poly coat on them.
The door jambs and astragal molding were just normal wood. Everything looked really nice when I finished. It went through one seasonal cycle and the stain on the doors had faded to almost non existent. The stain on the jambs and astragal was still perfect. Weird.
The thermal properties of the door was poor. It would get frost on the inside of the door because the door would get so cold and the interior humidity would freeze on it. Again, weird. The company insisted that the joint around the panel and frame needed to be silicon caulked. I did that and it seemed to help some. But that essentially meant the door couldn't be finished again. I can't imagine having to removed the caulk to reapply finish as nothing sticks to silicon.
I wasn't impressed. This was after I had built them a door a decade ago which performed as expected. Stained on the exterior and painted on the interior and no problems in the winter with interior frost.
12/2/24       #3: Thermally Modified Wood ...
Fred
Hi Leo,
How cold does it get in you region?
We are in the Canadian Rockies and sell into the Prairies as well.
I would suspect we could end up with the same thermal problem.
This did not happen with the Accoya.
I m suspecting the Thermal Modification of Hardwoods makes them denser and that may result in the loss of insulation properties.
Thank you,
Fred
12/2/24       #4: Thermally Modified Wood ...
North East. Normal night winter temps in the 20ºF's but as low as 5 below. Days swing around freezing. Not as bad as upper Maine with their -20ºF's
My theory about the wood is all the cells in the wood get ruptured and that's where the insulatory action happens. The thermal break so to speak. Without it the insulation value goes down.
But that's just a guess.
12/3/24       #5: Thermally Modified Wood ...
tom gardiner
I wouldn't think the wood density has changed based on my experience. I built a few modified poplar doors that would fully exposed to the elements. They have held together but I was disappointed to see the rich chocolate colour fades quickly with sun exposure. I recommend you make a finished sample and put it outside to simulate the conditions your doors will encounter.
Structurally I don't think you will have problems
12/3/24       #6: Thermally Modified Wood ...
I was thinking the thermal properties of the wood changed and made it less of an insulator.
3/26/25       #7: Thermally Modified Wood ...
rich Member
Website: http://www.handmadefurniturecompany.com
I used to use thermal poplar all the time for outside cabinet parts. Had good luck on maybe a dozen projects. Then all the projects we did after around 2010 went to hell. Had may half a dozen jobs where the doors fell apart, splintered, checked, etc. Really was a crappy result. We were buying our doors from Conestoga and using exterior glue. It was a very pretty product but it turned out to be no good. In my own house I bought a couple of exterior house door from Lemieux Doors out of thermal mahogany.. Same thing. On one door I can see a sliver of daylight through the panel. Really disappointed in how they weather. I finished it with a high quality exterior poly. I was a believer in the thermal wood propaganda and it really turned out to be a mistake.
3/26/25       #8: Thermally Modified Wood ...
One of my clients got a thermally modified pair of Mahogany doors and I stained and sprayed them with a 2K exterior.
After a year the stain disappeared on the doors. The jambs, small moldings and astragal all kept the stain just fine so it was the wood itself that somehow let the stain "evaporate". And the first year during the winter the doors had frost on the inside when it was freezing outside. Something doors I built never had happen. The manufacturer said I had to use a silicone caulk to seal up all the joints of the panels and stiles/rails. Which of course means that refinishing would be a nightmare when the time came.
Not a good experience.
4/29/25       #9: Thermally Modified Wood ...
Daiva Member
I’ve been looking into charred wood cladding options for a project and came across a supplier called TimberSol. They offer a range of charred cladding styles, and it seems like they use a Shou Sugi Ban-style process: https://timbersol.co.uk/product-category/charred-cladding/. Has anyone used their products before? I’m curious about the quality and how it holds up, especially in harsher climates. Would love to hear any feedback or alternative recommendations if anyone’s had experience with other suppliers.
