Subject: Re: machine lubrication
machine lubrication
5/28/25
Pete
Wondering what you guys are using for lubrication on a saw stop table saw, particularly the raise and tilt mechansim. Also for jointer and planer beds. I have been using regular paste wax on the jointer, planer etc but is there something that last longer?
5/29/25       #2: machine lubrication ...
BH Davis  Member
I had developed a trunion lowering squeal on my industrial Sawstop that I finally chased down last week. Looking down into the saw through the blade insert opening I looked toward the front and to the left. That is where the front lift guide post is located close to the saw's paddle switch corner.
I blew it all out and then just sprayed WD-40 onto the post. That solved the squeal problem.
For machine tops I use Bowling Alley wax. There are lots of spray on coatings that claim to do a great job but I've never had an issue with wax.
5/29/25       #3: machine lubrication ...
Pete
BH- Yes, its the saw stop that is driving me nuts. Seems like whatever I use just doesn't last. I need to get underneath it again today and see what I can do about it. I dont recall seeing anything in the manual about lubrication but I may have missed it.
I was under the assumption that WD40 has silicone in it and can cause fisheye/finish issues so I never use it in the shop.
5/29/25       #4: machine lubrication ...
Mitch Suber Member
I use Johnson's paste wax on my table surfaces like my table saw, planers and raw wood surface areas. A few weeks ago my 35 year old PM66 was getting extremely difficult to adjust when changing blade height and angles. For sometime it was a real problem, After watching an older employer struggle with adjustments, I decided something had to give. Even though overall the saw is in great shape. I had only been sporadically using oil, and a little grease in the undercarriage, avoiding WD-40. Since we do use Wd-40 in various places, I decided what the heck and cleaned my saw thoroughly, blew it out really well with compressed air, and hosed down the threaded screws and contact points. I didn't break down my saw, other than moving my motor cover, throat plate and front hatch. That did the trick, and it now adjust like a new saw and is once again a pleasure to use. I wish I had done this years ago.
5/30/25       #5: machine lubrication ...
BH Davis  Member
You can do a quick search online where you will find out WD-40 does not contain silicone.
6/14/25       #6: machine lubrication ...
Monica Chou Member
Website: https://www.zonledoors.com/
For the SawStop's lift and tilt mechanisms, we recommend using a dry Teflon or silicone-based spray lubricant for dust protection and smooth operation. For planer and planer surfaces, regular wax will work, but for longer-lasting protection, try Boeshield T-9 or Glidecote, which offer better rust resistance and a smoother, more durable surface.
6/14/25       #7: machine lubrication ...
Worm gears, grease.
Tables, I like paraffin wax.
