Subject: Re: Power feed install
Power feed install
7/9/25
Good day everyone. I picked up another shaper, I am going to mount a power feed on it shortly.
My question is which side of the table should you mount it on, pros and cons for both. I have been woodworking for years, 35 plus. I have installed a few power feeds on new shapers, when I am standing on the front of the machine I always put them on the back right corner, they have always worked great operationally in my opinion. I recently was looking at a shaper that had the power feed mounted on the rear left corner. It got me thinking, does it matter? Why one way and not the other.
So looking for any feedback. Thanks everyone.
7/9/25       #2: Power feed install ...
BH Davis  Member
I tend to put it on the back left corner. Can't say why and I don't think it really makes any difference. You feed a shaper from either direction so one way or the other it's going to be opposite of your feed direction.
I've articulated the feeder in every imaginable position over decades and never found the stand assembly be an interference to what I'm doing.
Of course no reason you couldn't drill and tap bolt holes in both corners if you ever found your initial install location to be a problem.
7/10/25       #3: Power feed install ...
duster
I've always installed mine on the back left corner as well. Mainly because it worked better with my dust collection arrangement.
7/10/25       #4: Power feed install ...
I'm also back left corner and also don't think think it matters.
7/10/25       #5: Power feed install ...
Mark
While I drilled both of the back corners for the tower base, I 90% of the time keep the feeder on the back right corner.
The reason is since I most often run CCW rotation and feed right to left, with the feeder mounted on the right, if it for some reason gets a little loose- Hey, it happens!- the feeder will swing away from the fence and cutterhead; on the left, it'll swing in.
Thre are times I'll need to set up on the left, but not a lot. Best is to have two bases bolted on.
7/10/25       #6: Power feed install ...
Mitch Suber Member
I tend to mount mine back left corner most of the time. I usually run my materials right to left, so I like my feeder in front of, or to the left of my cutter. My thinking is me or my operator is feeding material in from the right, and I don't want the feeder or the support arm in the right side area. To the left it's never in our way and carries the material away from the cutter as it should.
7/15/25       #7: Power feed install ...
Bruce H
All mine are on the back left except one which had them on both corners. (the right one is vertical)
9/2/25       #8: Power feed install ...
H LC Member
Website: http://www.hlc-metalparts.com/
Where the power feed is mounted typically depends primarily on your operating preferences, workspace, and interference with handwheels/controls. The right rear corner is common, as most people prefer to use their left hand for adjustments and their right hand for operation. However, some machine models or workshop layouts place it in the left rear corner to avoid interference with the operator or the workpiece. While both sides function identically, the key is determining which side is most convenient and doesn't interfere with your machining flow.
https://www.hlc-metalparts.com/news/blow-molding-85204986.html
