Subject: Re: Banding - Laminate glass doors
10/10/25
Ben Zacharias Member
Website: http://www.vangarde.com
Does anyone here have any tips or tricks to reduce the amount of time it takes to hand band the inside edge of the "stiles & rails" of a laminate door cut for glass (see pics)?
Currently we have having to tape of the face and back, spray glue, measure each length, cut banding, add banding to edge, hand trim face and back, etc.
Any ideas to save time would be extremely helpful.
10/11/25       #3: Banding - Laminate glass doors ...
Monica Chou Member
Website: https://www.zonledoors.com/
Our factory encountered this problem while making doors. Later, the workers came up with several ideas that significantly speed up the process:
1. Pre-cut edge tape: Cut common lengths in advance using a machine or a ruler and set aside. This way, you don't have to measure and cut with a ruler every time; you can just apply the pre-cut edge tape.
2. Use self-adhesive edge tape. There are also those with self-adhesive backings. Just peel off the adhesive and apply directly. No need to spray glue, wait for it to dry, or clean up residual glue.
3. Add a reversible workbench: Place the door on a reversible workbench. After applying one side, flip it over and apply the other side directly, without having to move the door or adjust the angle again.
These are the methods we've used, and we hope they'll be helpful to you.
10/11/25       #4: Banding - Laminate glass doors ...
Rich  Member
We use MDF as core and paint black
10/11/25       #5: Banding - Laminate glass doors ...
Monica - What is a "reversible workbench"? Do you have any pics? We have also not had good luck with double sided tape on particle board or MDF. Did you find a brand and model that works with these cores?
Rich - We have quite a few different laminates that are a wood grain so we would not be able to paint all of them, but I agree that would be a great option for a solid color
10/13/25       #6: Banding - Laminate glass doors ...
Monica Chou Member
I mistranslated it earlier. I wasn't referring to a "reversible workbench," but a "flip-top workbench," meaning a workbench with a reversible top, allowing you to work on both sides of a door panel from the same location without having to move the workpiece.Like the picture.
As for adhesive tape, the types we've used that work well are 3M VHB 5952 and Tesa 4965. They adhere more securely to particle board or MDF and are more heat-resistant.
View higher quality, full size image (1200 X 1200)
