Subject: Re: 8/4 tables
8/4 tables
11/7/25
Brian Heaton
What are your thoughts on using a beam saw to square up and size 8/4 hardwood tables? These are constructed mainly from red oak, standard procedure is to straight line and glue up panels that or oversize, surface to thickness and the trim and rip to correct dimensions. Wouldnt a beam saw do this efficiently? Say we need a 36x36 tables and have a 37x 37 blank. place the blank with grain lengthwise in the saw which then will make the first trim on the edge nearest you push the blank out and cut the width, then rotate the blank up against the fence and do the same for length. Of course the feed rate will need to be adjusted. I know a slider will do that but not with the ease or accuracy. What do you think?
11/8/25       #2: 8/4 tables ...
Hen Bob
We use our beam saw to size doors all the time, Don't see why it wouldn't work for that
