Subject: Re: Field Joints on Walnut Bartop Slabs
12/11/25
Troy Beverly
Website: http://iwswoodworking.com
I have been doing commercial restaurant bartops for many years through 3 different shops and I always get different opinions on the best way to treat on stie field seams. Our method is to build a in shop diewall and laser 1 inch thick subtops with spline and underside titejoints. We then titebond 3 our solid barslabs with cauls down to subtops and let dry 12 hours before unclamping. This works great. We then remove underside titejoints Mask off all endgrain mitre and butt joints and send for finishing. Ship slabs to site and here is the big question. I could just continue with titebond 3 at all field joints on site at install or should I use West System epoxy or something even more flexable like silicone? Whichever I use we mask both face sides of field joints pull sections together with underside titejoints and clean face of joints and remove tape let cure overnight. Any opinions on best product?
I was worried epoxy might crack at field joints due to slight wood movement. This is why I am leaning towards titebond 3.
1/5/26       #2: Field Joints on Walnut Bartop Slabs ...
David R Sochar
West would be my choice for any or all construction of the top. TBIII never gets solid and will creep out of joints in time, leaving a slight glue line anyone can feel.
If this is all solid contruction, be sure to have researched how much movement seasonally. If manmade materials, then you can use West without any precautions, sort of.
