Subject: Re: Bolection Moulding and Raised Panels
1/12/26
Gavin Hackeling
Hello, I am trying to understand this diagram depicting the cross sections of doors with raised panels and bolection moulding. If I understand correctly, the rails and stiles are grooved (e.g., 3/4" wide by 1/2" deep for an exterior door). The panels are raised, and the door has bolection moulding. The panels' tongues are too short; another piece of solid wood bridges the gap between the tongue and the rails/stiles' grooves.
Is this summary correct?
Do the lands and panels both float? If so, should I increase the expansion gaps? Should I use space balls between both the grooves and lands and the lands and panels?
Can anyone recommend any resources about this kind of construction?
Thanks!
View higher quality, full size image (1583 X 2131)
1/14/26       #2: Bolection Moulding and Raised Panel ...
David Sochar, a frequent contributor to this forum has written a detailed book on door construction. I am surprised he hasn't chimed in yet.
1/14/26       #3: Bolection Moulding and Raised Panel ...
BH Davis  Member
On the right hand drawing the lands do not need to float. On the left hand drawing I'd be inclined to have them loose though....or at least the center component of the 3-part build up.
I'd say you do not need a space ball between the land and the frame as there won't be much movement over that short width of the lands. I'd even be inclined to glue those to the rails and stiles.
Space balls for the running edges, or pinned centers on the butt ends would be appropriate for the raised panels though. And the bolection mouldings should be fixed by glue or nails to the lands and/or rails and stiles.
And quite frankly except for the added complexity of the construction process there is no reason not to mill the lands right into rails and stiles instead of adding them as separate pieces.
