Subject: Re: CVG Hemlock T&G Costs
6/5/26
Bob Holloway
We've been asked by a current client if we can provide 15,000 sq.ft of 1x6 VG Hemlock T&G material. This is not problem but such a large quantity I am nervous about pricing and was looking for some guidance on how other are calculating the costs of such material. We've been asked to provide the material prefinished. Below are some finer details of the needs.
1.We start with 2x6 RGH material (we buy it this way normally anyways for our normal production) 10-20' long material
2. We take directly from the bunk to vertical resaw machine with power feed. I calculated 180 hrs for this operation.
3. Then to the 5 sided moulder where we will profile in 1 pass - I calc 200 Hrs
4. Material moves to the 2 head widebelt for one pass sanding 120-150 -I Calc. 180 Hrs.
5. Then to the finish room (we don't have a dedicated spraying machine and it is all executed by hand so lots of labor in material handling and room for drying. We apply a High quality post cat PUR urethane coating both sides.
6. Scuff sand at widebelt with 220 grit (1 pass)
7. Spray face of material ( so a total 1 heavy coat at back side and 2 coats at face) I calc for the entire finish process 450 Hrs.
8. Packaging 60 hrs.
Total 1,070 man hours
Our shop rate is $110/hr.
Curious if anyone has any thoughts on my process or if I overlooked anything.
Thank you!
