Jamb legs
4/24/14
gary
I am curious how other shops are rabbetting your jamb legs for head jamb connection? Radial arm saws don't seem precise enough so I use a router jig which is precise but time consuming. Any thoughts would be appreciated.
4/24/14       #2: Jamb legs ...
Bruce
A designated radial arm saw with dadoe blade is the fastest way. And the cleanest.
I,d check the bearings on your saw to make sure there is not excessive play in the blade.
4/25/14       #3: Jamb legs ...
For interior legs, I agree with Bruce. When we hung 30 doors a day, we had a setup that clamped the jamb leg up to a rigid stop just under the radial saw with a 5/8" dado on it. The rigid stop controlled the depth, so we could make sides by the hundreds and then cut heads in advance, with tightly controlled openings.
We made our jambs with slight beveled edges, and that way the head and side did not come together well at all, but I was the only one that was bothered by that.
About 20 years ago, we changed to mitered heads and sides, glued and screwed. This works with square edges or beveled. We also could first attach the stops, then miter (on panel saw) and then assemble with a better, faster, stronger, and more appropriate joint. We still have control over the width, though we do not pre-hang in quantity like we used to.
4/25/14       #4: Jamb legs ...
Alan F.
David,
didn't the bevel make installing the casing simpler in the field and allow for wall deviations?
A-
4/25/14       #5: Jamb legs ...
Alan - Yes, that was the logic, to aid in casing fit and install. The carpenter we were supplying at that shop demanded and got beveled jambs, assembled casing on one side, with spline nailed miters, and an assembled loose casing tacked on over that. This was quick work, for the production builders.
As we moved up market, the carpenter/installers liked to fit the jambs to the width and scoffed at the 'flunkie' ways and beveled jambs. We changed over to square edged jambs and have never had a complaint, though we offer beveled.
