Solid surface set-up
5/2/14
If you were to set up your own solid surface shop from scratch what tools would you fill it with. I am talking about basic tools as well as more advanced tools. Also any special design for sawhorses that make fabrication easier, pictures would be appreciated.
5/4/14       #2: Solid surface set-up ...
Chris
I'd be interested in hearing the responses myself. I'm guessing routers, sanders, bandsaw, table saw and oodles of clamps.
High tech would of course have cnc also.
5/5/14       #3: Solid surface set-up ...
Dave
The sheets are big and heavy to move so most small shops I've seen start with a Vertical panel saw, several hand routers, several sanders, a bunch of clamps and templates, and some decent dust collectors.
Select Machinery www.selectmachineryinc.com has setup many new shops over the years and carries all the basics you need and gives accurate honest advice.
Select Machinery
5/7/14       #4: Solid surface set-up ...
We are not a SS fabricating shop BUT do a little as part of the entire project.
For straight work we always miter fold edges. Much faster that stacking. If the drop edge is fairly deep and curvy we thermoform it using forms made on the CNC. For surface sanding you will want a larger sander. We have a low cost 11" RO (Gem) that works well. Thermoforming is also used for custom lavs like you find in expensive restaurants. We have a 3 X 8' oven that works well. For hot, vacuum formed curvy things you need a silicone membrane.
