Entry doors glass
8/22/14
Kip  Member
Website: covenantcustomcabs.com
I am building a set of carriage doors with arched tops and glass panes across the top. What is the best way to make the trim molding for the inside of the door that holds the glass in? I will be using my Weaver door shapers to run my cope and stick and mullions. Would I just run a piece through the sticking shaper and rip the profiled edge off? If so then how would I rip the arched piece?
8/26/14       #2: Entry doors glass ...
Glass stops are made on the shaper, with wide stock being profiled and then ripped off the wider stock. The curved parts would be made from wider stock, shaped and then bandsawn free, with a template running on a rotary or fixed bearing surface, or any number of shaper techniques to make curved moldings.
4/28/15       #3: Entry doors glass ...
Alma Garcia Member
I would like to suggest you about use of good quality door panel. Also you can contact to some professionals for this.
oriental screen Bethesda MD
