Need hardware for pivoting window….
2/9/15
JeffD
I'm building a set of 3 transom windows, all interior. Basically just a way to enclose a room but still allow for ventilation. I'm trying to find pivoting hinges that allow me to have the windows pivot on the horizontal center. So far all I can find online is somewhat crude hardware not quite as refined as what I'd ideally want. Anyone have sources they could share?
Otherwise my only solution is to slide brass pins though the window frame into a metal cup in the jamb before I install the glass. Which should work fine, but not the easiest in terms of future removal:(
thanks,
JeffD
2/9/15       #2: Need hardware for pivoting window…. ...
gary
Jeff,
Try " GU Hardware" as they used to sell a great pivot hinge. Stick to European companies for sources as I have not seen anything made in the USA.
2/9/15       #3: Need hardware for pivoting window…. ...
Try Phelps at the link below. They have good quality old school window hardware and such. Call them since if it isn't in the catalog doesn't mean they don't have a source.
I'm unsure if you are tilting as in old school transoms or not, but 3 bar or 4 bar casement hinges will work nicely also.
Phelps
2/17/15       #4: Need hardware for pivoting window…. ...
JeffD
Thanks guys!
I checked out GU hardware and while pretty nice, is a bit too steep for what I'm trying got accomplish. I know I said I was looking for something "more refined", but that's a little too refined for this project:)
I also looked at Phelps but didn't see anything online for pivot hinges. I'll try calling them later this week, just been too busy lately as it seems like spring fever has hit and looking to be a busy spring!
thanks,
JeffD
2/19/15       #5: Need hardware for pivoting window…. ...
Steeliemark
I haven't really thought this through, not enough coffee yet, but-maybe knife hinges?
2/19/15       #6: Need hardware for pivoting window…. ...
Steeliemark
Had more coffee-
I thought I'd seen what you're looking for , found these-
http://www.kilianhardware.com/piwiha.html
http://www.vintagehardware.com/prodde
tail.php?prod=Transom-Window-Pivot-Hinges--Set-of-4-%28H-102%29
It was the pivot hinge I was thinking of, but in brass.
    Doucet Machinery
