wood clad metal door frames
5/12/15
jake
i have been asked to provide "wood clad metal door frames" for apartments.
they are using hollow metal doors which i can get "veneered" in walnut...but the frames? trying to get an answer from the arch but want to look intelligent.
do they usually just want these veneered? like with contact cement?
help would be appreciated.
5/13/15       #2: wood clad metal door frames ...
james mcgrew Member
Frames are Generally painted to match and wood overlay (Casing) goes to the inside perimeter edge.
If you were to return into the case it would effect the door stop on a metal case
View higher quality, full size image (662 X 798)
5/16/15       #3: wood clad metal door frames ...
AzFred  Member
There are two companies, to my knowledge, that offer veneer wrapped fire rated metal door frames for commercial installation. The names escape me but as I recall, Jacaranda Inc. provides the veneer and can probably direct you to the US manufacturers. 1-800-225-6384 Miriam, Ed, Mike or Tom for help
    Doucet Machinery
