Epoxy??
11/11/15
I need to take 2 factory make 30 light doors that are 36" wide x 112" tall and prep them for concealed vertical rod exit devices.
They are for exterior use and I was thinking of using an epoxy to glue up the edge.
Any comments or suggestions would be appreciated, the sooner the better I need to do these this weekend.
11/12/15       #2: Epoxy?? ...
Leo G
My go to epoxy has always been West system. Use the 105 Resin and 206 Hardener for most things. You can use the 205 hardener to speed things up, but pot life is compromised. You'll need a lot of clamps as it's an overnight cure.
They also have another product called six-10 which comes in a caulk style tube and has a mixing spout. The product is much thicker then the 105/205 combo.
11/12/15       #3: Epoxy?? ...
Jay
exterior doors? .. I use Resorcinol. (NOT powdered urea resin "brown glue")
I suggest either Aerodux 185 or Aerodux 500. (Dap "Marine Adhesive " is no longer made).
Epoxies are a good choice, but they have some inherent weaknesses/drawbacks 'they have their place! but I'd disagree with using an epoxy in an exterior door, at least when there's a better (available) choice, & there is:
Resorcinol is the final word for the application you just described
Hexion is another source of Resorcinol adhesives (trade name used to be "Cascophen" ) their latest resorcinol based adhesives may be of interest to you, & there is a support # on their website from which you can gain assistance, should you choose this manufacturer.
The only caveats with Resorcinol are that some consider it "finicky " (Which I do not)
-joints must fit, (poor gap filling properties)
-must stay within temperature range/pot life
-must apply proper clamping pressure
basically , -study the data sheet, thoroughly plan the operation and DON'T DEVIATE FROM THE INSTRUCTIONS
and you'll be rewarded with the best glue-up which can possibly be obtained. Further, this stuff has stood the test of time, so you can relax in the fact that your joints will not fail months or years later.
I hope this helps!
-best wishes
11/13/15       #5: Epoxy?? ...
I 2nd the use of Resorcinol. Long track record. Used properly it will not fail.
12/10/15       #6: Epoxy?? ...
Gene Wengert-WoodDoc
Resourcinol always has formaldehyde as a catalyst. Ventilation is essential when using and for some time afterwards as the "F" is released into the air.
Epoxy for exterior probably needs a uv stabilized type. Epoxy also needs a thick joint so that there is enuf adhesive to generate the required amount of heat for there to be a good cure. This is where many bad stories about epoxy come from- too much pressure so the glue line is too thin.
