hidden door on soss hinges
12/8/15
jacob
Attached is an image of a hidden door my client wants on a wall that is to be paneled.
They are showing a 1 3/4 door and on top of that a panel to match the rest of the wall.
Before i start- will that interfere with how the door moves?
12/8/15       #2: hidden door on soss hinges ...
Phil Hallam
I don't see any issues with the design. Soss hinges are well designed, however you may want to check out some of the brands that are adjustable, such as Tectus or Rockyork.
Be sure to space your hinges according to the manufacturers specs to distribute the weight correctly
12/8/15       #3: hidden door on soss hinges ...
Michael Woods  Member
Website: woodsworks.co
+1, Phil. I recently completed a project exactly like this. Used Sugatsune hinges. A bit more expensive than Soss but worth it because of the adjustability.
12/8/15       #4: hidden door on soss hinges ...
Geoff
You may already be aware of this. Soss hinges require a pretty deep mortise which extends way beyond the thickness of the jamb. Plan ahead to cut into the door framing. Also I would use their (soss') hinge template guide with Porter Cable guide bearing and correct Amana plunge router bit. You will need a large router because the bit for a 216 or 218 hinge is around 3 1/2" long.
With no disrespect to the other poster. Butt hinges have no built in adjust ability and we use them all the time.
12/9/15       #5: hidden door on soss hinges ...
Gavin
Website: http://soraghanwoodworking.net
I agree with Phil and mike , I do applications like this all the time and there are no issues I see other than remebering how deep the hinge mortise is . However we use Sugatsune hinges for their adjustability which . Soss hinges do not have .
Best of luck keep us posted on your results
12/9/15       #6: hidden door on soss hinges ...
jacob
thank you all.
i will be suing adjustable hinges..not the soss company ones.
can anyone help me re the hinge side of the door: as it has an extra 3/4" panel on top of it will there be any problems regarding closing -will it bind? i know i should make a sample but perhaps you know?
12/9/15       #7: hidden door on soss hinges ...
Gary Katz has a good article on a bookcase door where he used pivot hinges.
If this is just a door (not a bookcase), and it swings into the hidden space, then the hinge requirements are simplified greatly and butt hinges can be used. Swinging into the primary space will require hinges like Tectus - favored by far over Soss for their adjustability.
Thisiscarpentry.com - Hidden pivot bookcase - Gary Katz
12/11/18       #9: hidden door on soss hinges ...
Jim
Website: https://www.sugatsune.com/
Besides adjustibility, the other useful feature of the Sugatsune (HES3D-E190) hinges is that the hinge leaves separate. This means you can "plug-in" your door to the frame once complete.
Regarding the possibility of binding, contact Sugatsune's sales & tech support with your drawing. They can generally provide instructions on the reveal or chamfering the door to open outward to at least 90°. The main limit with any paneling or cladding on the face of the door when using invisible hinges is where the hinge is placed (relative to the door's thickness).
https://www.sugatsune.com/201apdf/184.pdf
    Doucet Machinery
