Divided Light Sashes
8/18/16
Kevin
I'm making some nine light sashes to match existing using a set of sash cutters from freeborn. My question is, is it necessary to reinforce the joints with a loose tenon or dowel, or is the stub tenon sufficient? These will be painted, so I thought about pin nailing them. Thanks.
8/18/16       #2: Divided Light Sashes ...
Leo G
Support them. Almost all windows mullions are tenoned into a mortise. When I do the occasional window sash I dowel mine with 1/4" x 2" dowels in between the muntons. It will aid in assembly.
8/18/16       #3: Divided Light Sashes ...
I make divided light sash with coped joints. The copes help hold thing in place. I also make the horizontal muntins run full width, and tenon into the rails/stiles, along with the cope/stick for alignment. The vertical that run from the horizontals are coped only, except the we do period sash report where we do not set the glass. For those we use a stub offset tenon (and cope) with each vertical munition, and a regular tenon (and cope) at the perimeter rail.
A nine light array - 3w x 3h - will have a bottom rail and top rail and 2 stiles. There will be two long horizontal muntins that tenon into the stiles, and six vertical muntins - four short vertical muntins that have an offset stub tenon on one end and a longer tenon on the end that goes into the top or bottom rail. The other two vertical muntins that run in between the upper and lower row of 3 openings will have offset stub tenons on each end. All the above is fully coped and stuck. Good tooling and a good setup will make a cope joint that will stay in place once the parts are pressed together.
However, if we set insulated or other glass in our work we forego the stub tenons in the field of stick work. We seal the glass on both sides with sealant, so the sash develops a great amount of rigidity from that. We make sure everything is aligned, set the glass and stops, let it all cure and clean it up. It is solid.
The photos are are of a pine project that shows all the parts on the bench, including the door (no divided lights). The divided lights in the sidelights did not require stub tenons on the verticals.
There are no metal pins or staples in the work shown. Some variations may require something more in the way of metal fasteners, but those are quite different from standard divided light work.
View higher quality, full size image (2429 X 1995)
    Doucet Machinery
