Tectus Hinges
1/16/18
Gary
Has anyone used the Tectus hinges from Simonswerk on Solid Core interior doors? They are similar to Soss hinges but with adjustability. Are they reliable enough to hold the margins or does their adjustability mean you can adjust the margins as things move? Did you use the templates they provide or make your own? Thank you
1/16/18       #2: Tectus Hinges ...
Kevin Jenness
I've used Tectus hinges several times on heavy doors with the supplied templates (which you can rent if you don't want to purchase). They are excellent, easy to adjust and stay adjusted. Expensive but well worth it.
1/17/18       #4: Tectus Hinges ...
Wood Dust
I have used both the Tectus and the Sugastune version. They are both amazing hinges and well worth the money. I have made my own jigs or routed them in with the CNC.
1/17/18       #5: Tectus Hinges ...
Dan
Tectus hinges are excellent high quality hinges. We deal with Hafele for Tectus hinges. Making templates seems to be the best method for routing short of having a CNC that can do the job.
1/17/18       #6: Tectus Hinges ...
We have used Tectus hinges for heavy doors several times. Excellent hinges, and the jigs make them easy to set.
The first set is now 6 years out there, and no complaints or adjustments required. We fit and hang in the shop, but once the door is set, it is great to go in and make fine adjustments as needed. These really make Soss hinges look primitive.
We bought/rented from Index-D and they helped us select the hinges and place them on the doors.
Below is an article I wrote for the Gary Katz website that has good info and pictures.
View higher quality, full size image (1296 X 972)
Tectus Hinges
1/17/18       #7: Tectus Hinges ...
Alex Sponsor - Rangate
Website: http://rangate.com
Extremely helpful guide with easy-to-grasp companion photography, thank you for putting that together, David.
