WADKIN
6/27/18
DOM
Hey all. I just bought a ga series moulder and want to switch it to high voltage. I don't have any schematics. I called England. No dice. Anyone have anything out there or know another resource? Thanks.
6/27/18       #2: WADKIN ...
Russ
Website: http://www.mr-moulding-knives.com
The moderator of this forum may be able to help you on this.
You will probably need to reconfigure the wiring on each motor to high voltage, feed beam motor and feed system motor, switch a few wires on the transformer and get new circuit breakers for each motor in the electrical cabinet. Woodtech I believe is the go to people for Wadkin machinery.
Good Luck
Russ @ MR
http://www.woodtechtooling.com/
6/27/18       #3: WADKIN ...
Doug Clayton
we had a question on a 70's wadkin shaper motor. finally called the company that built the motor ( name on motor plate) that had tech support based in canada. they were helpful.
6/27/18       #4: WADKIN ...
DOM
Thanks Doug. I tried that. Since theres multiple motors and a transformer they couldn't help.
6/27/18       #5: WADKIN ...
Dustin orth
Find a good industrial electrician, it will be easier on you.
6/28/18       #6: WADKIN ...
Fred
Hi Dom,
Cant you use a transformer to change you voltage?
7/1/18       #7: WADKIN ...
Jeff
Best advice I've seen? Hire an industrial electrician!
Brought two massive old Wadkin 7 and 5 head molders to St Croix several years back and one of the mothers got banged up pretty bad on removeal from the container. Had a local guy weld up the case and a local electrician rebuild the motor.
The thing was pretty mangled, but the two of them got it working again.
Great machines, those Watkins!
    Doucet Machinery
