Thick door hinge
8/31/18
Gene B Crain Member
Website: http://vectorstudio22.com
I have louver closet doors to mount with the stiles and rails 4cm x 4cm. The closet sides are 4cm wide and I need the overlay to be 37cm. I done the hours long google searching for the hinges but can't find what I need.The hinges need to be soft close type.
Anyone have any source for this type of hinge?
9/1/18       #2: Thick door hinge ...
james e mcgrew Member
Both Blum and Salice have some solutions for this, I would hate to see it yet i have seen some "notch" the depth for overlay
9/1/18       #3: Thick door hinge ...
Gene B Crain Member
A typo error the overlay needs to be 3.7cm.
and yes James the "notch" is not an option in this application. Thank you for the reply.
9/1/18       #4: Thick door hinge ...
You will have an easier time looking for mm dimensions. No one uses cm. Only mm and m.
9/2/18       #5: Thick door hinge ...
Gene B Crain Member
Bueno los stiles son 40mm y estoy buscando bisagras con un overlay de 37.5mm
    Doucet Machinery
