Raised Moulding Doors
7/6/20
Daniel Member
HI All,
We have been playing with the idea of running some raised molding doors similar to the Masonite Bellagio. We don't currently run a CNC. I have the tooling for a shaper to cut the profile we want but have only ran it straight in Maple. Loose beading and glazed it on both sides. Being a small 1" square profile i'm not sure how one would run this in an arch. The back/underside would need to be notched to fit over the square edge of the door "frame". Thoughts?
View higher quality, full size image (960 X 960)
7/6/20       #2: Raised Moulding Doors ...
Wood stain and clear or paint?
7/6/20       #3: Raised Moulding Doors ...
Daniel Member
This particular job is Paint grade.
7/6/20       #4: Raised Moulding Doors ...
The curved molding can be run as a “stand up” and fed against the shaper fences. That is for the profile. The rabbet(s) can be run flat, from below, with a template, or fenced off bearings or fingers.
Draw cross sections to see what you can and can't do.
It is called a “bolection” molding, by the way.
When Masonite decides to make a door, they copy real examples of wood doors. If a woodworker were to design and build a style of doors, I would hope they would find better inspiration than a maker of fake doors.
7/6/20       #5: Raised Moulding Doors ...
That radius could easily be run on a Williams & Hussey molder. Of course you'd have to get knives made for that profile and still cut the rabbet on the underside with a router or shaper.
