Panel mounting hardware
8/17/20
Pete
I'm in the early stages of designing a columbarium for a church. The piece is basically a honeycomb box with a 12" by 12" panel that covers the honeycomb opening. The panel needs to be held in place but also be removable. Ive seen images of a decorative washer type hardware on the corners of each panel. Any idea on a source for hardware for this application?
8/17/20       #2: Panel mounting hardware ...
D Brown
They may be called "Finish Washers" I have used them try a search. Good luck.
8/17/20       #3: Panel mounting hardware ...
perley bowen
You could use magnet fastened to the back side of panels. Perley
8/18/20       #4: Panel mounting hardware ...
Mark B
We did a large project with fastmout fasteners. They sound like a good fit.
8/18/20       #5: Panel mounting hardware ...
Forgot to mention, James McGrew posted a link to another option in a thread a bit back that looked like a great solution as well,
https://www.starhanger.com/
