Stairs / Attachment methods
11/3/20
Skydiver Member
I have a 3 sets of open stairs to build. I want to pre build them as a break down set , have them stained and finished and shipped to the site. What attachment methods have other stair builders used to secure the treads to the stringers. other than screwing through the outside of the stringer and plugging the hole.
I was thinking about using hanger bolts in the stringers and bolting them through the underside of the tread, then using a router to flush trim the plugs with the finish.
Any thoughts on that.
11/3/20       #2: Stairs / Attachment methods ...
Standard open treads are usually made with an angled router bit like a dovetail bit but with a very shallow angle. You route slots in the stringers that trap the treads and the entry of the slot is wider which allows a wedge to be place in the slot locking the tread in place. Sometime people put a nail in the wedge to secure it, others don't.
11/4/20       #3: Stairs / Attachment methods ...
Mark
Unless your stringers are thick- 1-1/4"+ - a hanger bolt might not get enough purchase
I have used pocket screws but had 7/8" to screw to with a 1/2" mortise. I carefully used urethane adhesive also.
11/4/20       #4: Stairs / Attachment methods ...
Skydiver Member
I tried the pocket hole thing before , i didn’t much like it.
The stringers will be 1 3/4” thick with treads 3” thick in Birch or maple
11/5/20       #5: Stairs / Attachment methods ...
Mark
At those thicknesses, railbolts/hanger bolts should work ok.
I still recommend a good flexible adhesive to combat squeaks.
11/9/20       #6: Stairs / Attachment methods ...
Walter Member
I haven't tried this, but it's intriguing. It uses metal angle brackets under each tread.
https://youtu.be/IK9Pm9ZLmQI
Video of attaching treads from under
