Wire Brushed Doors
11/4/21
gary
I am a door builder with a deep background but have never built wire brushed doors. As far as glueing the stiles and rails together it seams that a european style v-groove at the joints would be very helpful but my customer does not want the look of it. I am planning to wire brush the stiles and rails before gluing them together. So the glue-up will be my biggest issue; how to keep glue from migrating into the surface areas. ( perhaps using masking tape to reduce the migration would help) but my question is this: is there a method to this challenge that other fabricators have developed to deal with this challenge ?
11/5/21       #2: Wire Brushed Doors ...
james e mcgrew  Member
Tape .125 ply or say galvanized plate at seam before brushing,
Best wat is to make assemble then disassemble and brush parts before final assembly
11/5/21       #3: Wire Brushed Doors ...
Whoops should have read better and after coffee.
11/7/21       #4: Wire Brushed Doors ...
nicko
You could apply some Waxilit glue release to the surfaces and and don't wipe your squeeze out off. The glue will just peel off the Waxilit when dry. Then clean the Waxilit off with some methyl hydrate or other non oily solvent before finishing.
Hope that helps........nicko
    Doucet Machinery
