Mirror Clad Doors
11/9/21
gary
I am wondering if there is a successful way to attach mirror cladding to one side of a flush door without it bowing the door and looking like a funhouse mirror ? Putting anything on just one side of a door is usually a bad idea since it creates an imbalance.
Maybe a steel frame door will stay flat ?
11/9/21       #2: Mirror Clad Doors ...
Just screw it in place with mirror tabs.
11/10/21       #3: Mirror Clad Doors ...
Gary,
I will let someone with experience answer your specific question but don't forget the hinging. You will need to consider the thickness of the back substrate plus the thickness of the glass when selecting the hinge type.
Dennis
11/10/21       #4: Mirror Clad Doors ...
I have done several projects with applied mirror or back painted glass on slab doors. The glass was applied with silicone (make sure the silicone is compatible with mirrors). I did not have any issues with warping.
11/10/21       #5: Mirror Clad Doors ...
Bruce H
I tell my customers "no". I'll make a glass frame of wood and put a mirror in it. If they want the tri-fold look there are plenty on the market to buy. The nice ones are expensive and don't come in custom sizes. That usually solves the issue.
11/11/21       #6: Mirror Clad Doors ...
No problems whatsoever bonding full height mirrors directly to melamine or nice smooth panel doors. Make sure you use the correct silicone or it damages the mirror. The hinges keep the door straight.
I've got two in my own house on wardrobe doors that I built. We've done at least twenty in customers houses over the years with no problems.
There are tons of store bought vanities that have bonded mirrors.
I'm all about balanced panels until it comes to some of the odd stuff. Then its based on experience. You don't have to go nutz with the silicone.
11/13/21       #7: Mirror Clad Doors ...
D Brown
An adhesive made just for this application is called mirror mastic. good luck
