Solid wood stair treads
12/6/21
Lu Member
I'm planning to glue up, face to face alternating grain direction. What would be a good way of making a stable , strong glue up of that volume.
Thanks,
Lu
12/6/21       #2: Solid wood stair treads ...
Stair treads - so 12 -14 treads at 1" x 11-1/2" x length? is my guess.
Typically these are made from 5/4 Oak, Maple or Poplar. Often glued for width. Some people think it is good practice to alternate ring direction in the edge gluing, so one piece is curve up, the next is curve down. I do not think it matters.
You sound as if you want to make plywood treads?
The more information you offer, the better quality answers you will receive.
2/5/22       #3: Solid wood stair treads ...
Nate Cougill  Member
Website: http://www.cougilldiversified.com
Any reason why they have to be solid? I’ve often seen with with a plywood core and veneered bottom. Still looks great, but more stable and less lumber required.
2/20/24       #4: Solid wood stair treads ...
Gairly Member
Selecting the right adhesive is essential for a strong glue-up. Consider using a high-quality woodworking glue specifically designed for your project. Examples include wood glue, polyurethane glue, or epoxy adhesive, depending on the specific requirements of your project.
    Doucet Machinery
