finger joint clamp for radial door rails and casings
12/29/21
Mark Ward Member
Looking for something on the market if anyone's familiar with one and also looking for any input on a good 1-1/4" shaper finger joint knife that will handle up to 2-1/4" stock.
Thanks,
Mark
12/30/21       #2: finger joint clamp for radial door ...
John
Website: http://artisanmillshop.com
Give Greg at Rangate a call
1/1/22       #3: finger joint clamp for radial door ...
BH Davis  Member
Although I think it is no longer available Rangate used to sell a pneumatic machine that did the job. It had a double table with a gap between the two sides. One side was fixed in place and the other moved towards the fixed side by air pressure.
You air clamped one arch segment on the fixed table, and the other arched segment on the moving table. Pressing the activation button brought the moving side into the fixed side, thus pulling the two sides of the joint together. You had to leave it like that until the glue set, or use a wood welder like the old Workrite units to set the glue.
Of course there are many other creative ways to pull this off with clamps and home made fixtures. The pneumatic unit above though is the only machine I know of that was specifically designed and sold for his purpose.
There was though, also a while back, a custom designed hand clamp that did the job. It also had a fixed side and a moving side, with rotating, rubber coated pivoting ears that grabbed the wood.
You slid a pair of the pivoting ears over the segment on one side of the joint, one ear on top of the segment and the other below, and the opposite pair of pivoting ears over the other side of the joint. Then you turned a hand screw to bring the two sets of ears closer to each other. As long as the rubber tipped pivoting ears grabbed the wood successfully, the two segments came together, thus closing the finger joint. We never got it to work smoothly enough to incorporate into everyday use, but it did come in handy occasionally for repairs.
1/4/22       #4: finger joint clamp for radial door ...
Joe Calhoon
I had the Arch Press BH mentions. They are no longer made but Soukup makes one. See link.
Since semi retiring and scaling back my work I found a old European hand clamp for this and sold the Archpress.
I have looked for a manufacturer of these in Europe with no luck.
For tooling I use my old Garniga adjustable finger joint cutter. 14mm to about 100mm thickness possible. Rangate sells a newer version of this made by Zuani.
View higher quality, full size image (2794 X 3725)
View higher quality, full size image (3752 X 2814)
https://https://soukupamerica.com/products/clamping-squaring-equipment/segment#segment
1/4/22       #5: finger joint clamp for radial door ...
Joe Calhoon
The Soukup link didn’t work. Try this
1/7/22       #7: finger joint clamp for radial door ...
Mark Ward Member
I'm new to posting here and guess I missed the "keep me posted" option first go around.
I really appreciate the responses guys. I had in mind a hand operated clamp considering the small size of my shop and infrequency of need up to this point but have a mahogany interior door job coming up with around 20 radial transoms. We also build the occasional radial shutter or gate.
I've never used finger joints so can only guess at how much pressure's required to get a good joint. After enlarging the picture of Rangate's arch clamp to get a closer look, my first thought was how much pressure would the rubber cams hold?
I'd guess from BH's last paragraph it's the same style clamp he tried but didn't care for. That post saved me $300.00
I'd love to find something more substantial like Joe's old European clamp. Also appreciate the Zuani referral Joe.
The time and aggravation involved in building something like this from scratch isn't attractive but may end up being the way to go. I've got several months to look... maybe e-bay......
Thanks again guys,
Mark
1/7/22       #9: finger joint clamp for radial door ...
BH Davis  Member
Couldn't find a photo or reference to this machine online but finally thought to look in old insurance photos and found it.
The pneumatic press I was referencing above was the Gartop Segment Press. Photo attached. This is a great solution if you can find one.
