Slatted wood wall
2/28/22
Anthonyg Member
Hello all
Hope i can pick your brain for a way to make slatted wood wall cladding with low cost and still look good using mdf venner laminated chipboard....
Thank you
View higher quality, full size image (530 X 530)
2/28/22       #2: Slatted wood wall ...
Mark B
Are you the design architect/engineer? Or someone tasking you with that? Usually this work is pretty well spec'd out when supplied to you?
2/28/22       #3: Slatted wood wall ...
Anthonyg Member
I am working on a new project and i am looking to cut down on cost for slatted wood wall
I use to put veneer on mdf and install massive wood on top
It adds a big cost to the claddings
View higher quality, full size image (1079 X 2321)
2/28/22       #4: Slatted wood wall ...
Anthonyg Member
If any one have some ideas with picture will be more than perfect
Love this forum
3/1/22       #5: Slatted wood wall ...
Danny
Website: http://www.litefootcabinetry.com
Hi Anthony
I was just looking through Outwater industries and they have a slat wall system that might be what your looking for.
Another system is Ikonni but they are probably just as expensive as your original construction.
Good luck
Danny
3/3/22       #6: Slatted wood wall ...
Nate Cougill  Member
Website: http://www.cougilldiversified.com
I’d have to price it, but up high like this, you could do aluminum or plastic square tubing wrapped in DiNoc film.
