Glue Joint Cutters: stacked on top of each other ?
3/6/22
gary
It seems like it might be possible to stack 2 glue joint cutters, from the same manufacturer , on top of each other on a shaper to be able to glue joint, for example, 3-1/2" thick material. Has anyone tried this?
Thank you in advance
3/7/22       #2: Glue Joint Cutters: stacked on top ...
Depends on how the teeth are ground and the distance to the end of the cutter head. Call your tooling supplier
3/7/22       #3: Glue Joint Cutters: stacked on top ...
At the minimum, send them out to sharpened with an O.D. Match request to insure that the O D is the same so things will glue up square.
I would look at the Rangate Glue Joint Cutter. Far more useful than 2 of the conventional cutters.
View higher quality, full size image (480 X 320)
3/7/22       #4: Glue Joint Cutters: stacked on top ...
gary
I already have an Amana insert head which I like but not sure if my carbide service can touch those up. It would be quite a waste to buy another and have it un-stackable. I will get a cost from Schmidt for a 3" tall reversible head. Rangate seems very overpriced but my Zuani heads do work well.
3/8/22       #5: Glue Joint Cutters: stacked on top ...
BH Davis  Member
Make sure you have a matched set and a spindle large enough to handle the stack.
