Wood Identification
7/21/22
Gary Cernoch Member
Website: http://customwindowstexas.com
A friend of mine has recently come across a sticker under a bundle of plywood that is intriguing and unknown to either of us. The grain has the appearance of white oak or perhaps ash, the color is a coffee brown and it has a sweet molasses smell. My only guess is sasafrass but I have never seen sasafrass in person.
Any ideas? I have attached photos.
Gary
7/21/22       #2: Wood Identification ...
Sassafras has a spicy smell. There is a heat process to render wood less susceptible to rot and the thermally modified wood can be called roasted or caramelized. Sorry I can't directly identify that sample.
7/21/22       #3: Wood Identification ...
Gary Cernoch Member
Thanks for that information, Rich, I hadn't thought about thermal treatment. Would thermal treatment change the wood color all the way through? The square end cut is a fresh cut on the piece and there is no change in the color intensity toward the center. Do you know what the thermal modification process is called?
Gary
7/21/22       #4: Wood Identification ...
Roasted or thermally modified ash. That's the colour although the process can be controlled for depth of colour.
7/21/22       #5: Wood Identification ...
https://deltamillworks.com/thermally-modified-wood-an-eco-friendly-durable-alterna
tive/
https://en.wikipedia.org/wiki/Thermally_modified_wood
7/22/22       #6: Wood Identification ...
Mark Ragnar Bakunda  Member
Website: http://www.ragnarfurniture.com
Where was the plywood produced? That might help narrow down the where the tree was from.
7/22/22       #7: Wood Identification ...
Sassafras would be an easy tell as it is dead soft and very light. Unmistakable root beer smell. The molasses smell doesnt seem a fit.
7/22/22       #8: Wood Identification ...
Gary Cernoch Member
Thanks everyone for your input. I believe it must be thermally modified ash or oak from all appearances
Gary.
7/22/22       #9: Wood Identification ...
Usually thermally modified smells burnt-ish.
