Aftermarket digital readout
11/23/22
Mack s
Looking for recommendations and or advice on digital readout scales I can install on a tenoner and a molder
11/23/22       #2: Aftermarket digital readout ...
Mark B
Proscale is going to be the main recommendation. Spendy but by far the best quality. I have some Igaging import scales that read down to .0005 but they are glitchy. You get what you pay for. Avoid anything like Wixey. The resolution is not accurate enough.
11/23/22       #3: Aftermarket digital readout ...
Yes, Proscale is what I have in the shop. They use up batteries quickly, and have quirky clips for the batteries that look like an afterthought.
The have made a retrofit to replace the odd clips, but it is so expensive, it would be $1800 to change over for my shop! Just slightly less than replacing them with new units.
11/24/22       #4: Aftermarket digital readout ...
Dustin Orth  Member
Pro scale is the way to go. I did a modification on mine so that I don't need batteries. They have a setting in the programming that allows for this. I put them on my molder and widebelt sander. Reliable and customer support has been very good. Give them a call, will be worth your time.
