Laminated stiles
4/28/23
Al
I have some tall cabinet doors 90” to make. I probably need 7/8” to 1-1/8” thick doors and will be made of hard maple. I have laminated boards for 1-1/2” interior passage doors by gluing 13/16” boards face to face. So not to waste material can you put 13/16” thickness with a 3/8” thickness or do you need to keep them equal. My thinking is they should be the same thickness but thought I would ask. It seems when you laminate two boards together you gain a lot of stability.
Thanks,
Al
4/28/23       #2: Laminated stiles ...
Should always be an odd number of layers. Equal would probably be a good thing for stability.
4/30/23       #3: Laminated stiles ...
Al
Thanks Leo. I now remember last time I did this for passage doors it was 3 layers of 9/16” each layer. Glad I asked.
5/2/23       #4: Laminated stiles ...
I have laminated stiles with unequal thickness many times. I never had a problem. Shipped sveral thousand doors, with only 3 warping, not with laminated stiles. You should use the best wood, from the same kiln run.
5/3/23       #5: Laminated stiles ...
Mindaugas Member
Make sure the wood is properly dried and acclimated to your shop environment before laminating. Use good quality glue and apply even pressure during clamping. Allow sufficient time for the glue to dry before machining the stiles. If you follow these steps, you should have no problem with laminating styles of unequal thickness.
5/5/23       #6: Laminated stiles ...
bwoki Member
I find yours to be completely different.
https://fnafsecuritybreach3.com/
10/6/23       #8: Laminated stiles ...
nayantheking
Website: http://lanaleephoto.com/guestbook.html
Thanks for sharing
    Doucet Machinery
