VENEER LIFTING
6/11/23
Orin N Zelenak Member
See photo below:
1) Rift white oak, wirebrushed, hot pressed onto MDF door face
2) Veneer was not bubbled when raw
3) Black stain is oil based - 1 thin topcoat 2k poly
4) Veneer lift is at the edge of a leaf and does not extend past the veneer seam so it's not simply that there was a strip of glue missing
5) We were told that the veneer leaves can sometimes be thinner toward their edge and that after wire-brushing they are thinner still and more fragile (makes sense)
6) Possibilities: a) solvent in poly softening glue line? b) poly curing stressed weak veneer? something else?
7) Tests: We're going to try to replicate and spray / soak with water and also stain / poly.
8) If the water works we'd consider wetting all the raw veneer (once pressed onto panels / doors) to test before finishing. Does anyone do this or have another way of guarding against this?
Thanks in advance for any guidance and suggestions.
VENEER_LIFT.pdf
6/11/23       #2: VENEER LIFTING ...
Is it just on that one seam? In my opinion that eliminates all the solvent related issues since the rest of the door seams are okay.
6/11/23       #3: VENEER LIFTING ...
Orin Zelenak Member
Rich, I agree. I’m wondering if it’s possible that the veneer is thinner where it lifted to the point where solvent was more able to penetrate to the glue line. Not sure about how the solvent is sorbing into the wood though.
6/12/23       #4: VENEER LIFTING ...
I would think that this is caused by one piece of veneer that was sliced thin. I have come across it occasionally. Less likely to be the wire brushing. Bummer.
6/12/23       #5: VENEER LIFTING ...
I'd put a small bet on adhesive starved area, or you wire brushed a bit too soon. The wrinkles look like the veneer expanded at some time in the process.
6/12/23       #6: VENEER LIFTING ...
Dave Edgerton  Member
Adhesive type? Pva or plastic resin?
6/14/23       #7: VENEER LIFTING ...
Go back to your veneer stock and mic the edges. I have run into veneers that are supposed to be .060” thick, but one edge will be .030” or so. It will run the full length of the veneer. With a rigid caul or press, there is no or inadequate pressure along the thin edge so the veneer does not bond.
Fortunately, the veneer in your case will allow a shallow route the full length of the panel just deep enough to flush the replacement veneer with the original. The rift pattern will allow a relatively easy match.
    Doucet Machinery
