Lineal ft price
8/15/23
Moose Member
What is the going rate to run mouldings. I have woodmaster and the wood is going to be supplied just need to figure how much the charge per ft.
8/16/23       #2: Lineal ft price ...
I think my moulding guy is $.35?
Plus knives, setup, and material
8/17/23       #3: Lineal ft price ...
Wow Karl, that guy is cheap. If a restoration guy wanted 20' of custom crown, the guy would only charge $7 for labor? I wouldn't flip a switch for that money.
8/17/23       #4: Lineal ft price ...
Nope.
He'd charge $7 to run it through the moulder.
I think his setup is $75
If you need 10" of steel cut for matching knives, that's another charge. I haven't had him cut knives for me in quite a while, I don't remember what it was. $50 an inch maybe? Call that $500.
So, 7+75+500, that'd be $582 to get your matching 20' of trim. Or $29.10 per foot. Plus material
But if you run 2000' it's now $.64 per foot. Plus material
He's got knives I've ran thousands of feet of material with, so cheap enough. And it always pays to dilute that setup charge when you can.
8/18/23       #5: Lineal ft price ...
If he charges $500 for knives, then that is where all his profit is. I can get a set of custom knives made for my Williams and Hussey for around $140 for an 1 1/2" wide knife set up to $400 for a set of 7" wide knives. One thing about custom work is the time lost while the customer talks to you. I never had anyone come into the shop and not stay for less than 30 minutes, and then talk again when they pick up the stock. Would you run 20' of stock for $7? All those other costs pay for the other labor and parts. If he truly is hiding the real profit in mark ups in his other labor, it starts to smell like dishonesty. Just like when I moved my cell phone service to another company. She swore my monthly bill would less than $100. Then the first bill came and it was $130. Sure, other fees and charges, but the price out the door should be explained. You guy says he charges $.35/ft. Then instead of paying $7, you pay $582. I know you like him, but I don't like his pricing procedure.
8/19/23       #6: Lineal ft price ...
I don't think he's carving out a living cutting a few sets of knives a month. I'm guessing it's the semi's of gravy train paneling he runs
8/22/23       #7: Lineal ft price ...
Dustin Orth  Member
My prices to run material are dependent on how many lineal feet the order is, smaller runs, way higher per foot price. How many heads do I need to change over, how much material am I taking off, can it go straight to molder or does it have to ripped first? A lot of variables for just figuring a price. Dustin
9/5/23       #8: Lineal ft price ...
Mark B
There is zero money in running sub-100' runs on a W&H unless you have restoration customers who will pay 2-3x Karls short run prices. 30-40$ a foot would be minimum by the time you source dead clean stock for moulder blanks (or you keep it in house), prep, knives, run it (with extra for snipe, tear out, etc..)
They, and woodmasters, can be handy machines "IF" you have a market to support it. After you pass 500' your losing your shirt. There is a sweet spot for these small run machines but its very focused. Short run (sub 50') better be willing to pay 20-40$ a foot with knife grinding and setup, up closer to 500' a good bit less but still restoration pricing, after that, find a multi-head shop.
Forget about runs with back side, or 4 side machining. Even a simple back relief requiring two setups on a W&H or woodmaster and your numbers go even further through the roof.
