Exterior Wood Cladding - "Panels"
10/23/23
Max
I am planning to use 3/4" solid western red cedar cladding on a new house project in a tropical environment (south FL).
However, rather than expressed wood boards with a 1/8" joint between each board, I would like to glue the T&G boards into hairline joints onto some sort of substrate, effectively creating a panel that could then be applied like other facade cladding panels in a rainscreen system (panel sizes would be approx. 4'x8'). The desire is for a panelized look closer to an interior wood veneer panel rather than individual expressed boards.
On another project, an architect used 3/4" T&G teak glued and fastened into a 2-1/2" solid mahogany core and then another 3/4" T&G teak on the back side to balance. This was for a unique entryway condition - so ideally for this application, there is some other substrate that we could adhere and fasten to on one side since this will be detailed like a rainscreen.
Note - money is not an issue. My question is does this seem crazy from a functional / weathering perspective?
10/23/23       #2: Exterior Wood Cladding - "Pane ...
It's not practical for the life of the cedar. Wood moves from side to side during different weather conditions. Plywood doesn't. Cedar shingles live because the installer gets air behind the shingles and they dry out quickly. Your suggestion ignores the practices of centuries of success.
10/23/23       #3: Exterior Wood Cladding - "Pane ...
Max
I think what I am describing is akin to a cross laminated panel that are becoming more common as structural systems. Why could I not make a custom cross laminated, glued up sandwich panel and use it as a rainscreen?Lamboo has a bamboo wood product for exteriors that does this in principle.
10/23/23       #4: Exterior Wood Cladding - "Pane ...
Chicago Millwork
CLT panels do not get used in exterior applications, yes they are used for structures but then they are clad with something. Like Rich said what you are proposing simply will not last especially in a tropical environment. If you want cedar cladding look into rainscreen profiles.Even then I'm not sure about South Florida and cedar siding but I'm not an expert on coatings. History is not on your side with this idea.
10/24/23       #5: Exterior Wood Cladding - "Pane ...
Bamboo is grass, Cedar is wood. The cellular characteristics are much different when it comes to expansion and contraction.
10/24/23       #6: Exterior Wood Cladding - "Pane ...
If you don't like my advice, go ahead and do it. If money is no object, just bill them for replacement every few years.
10/24/23       #7: Exterior Wood Cladding - "Pane ...
Max
Appreciate the advice - I am by no means a wood expert. Just asking the question!
There is an example I saw at a museum in south florida - attached image below. It is teak cladding. Although not entirely exposed, it is set back under a roof, it is exterior. It was built in 2013 and I was there recently and the wood is holding up quite well, although it needs to be refinished. I've linked to an image below.
View larger image
10/24/23       #8: Exterior Wood Cladding - "Pane ...
Chicago Millwork
The overhang in the photo is massive and far from "normal" at that point it's almost inside. I get what you want to do ut it's not going to work how you envision it.
10/31/23       #9: Exterior Wood Cladding - "Pane ...
David R Sochar  Member
Website: http://www.acornwoodworks. nzs5z967fd com
You can make a panel with the look of solid cedar but it must be balanced - the same both sides. As simple as a three ply -face, core ,face - to a seven ply or more assembly. The cedar you see may be thin, like 1/16th inch thick, two panels thick,with each panel at five ply or more, with a core not more than 3/4” or so. Talk to Brett at Indiana Architectural Supply. They know the parameters.
LumberCore, for those over 65. Fabulous product. Five ply, if I recall.
7/16/24       #10: Exterior Wood Cladding - "Pane ...
RDBL
Website: http://rdbl.net/
In case you want to raise the smooth and strong reduction of your property, don’t overlook outdoor wood coverings. those bendy panels additionally create layout possibilities at the same time as present robust protection from the factors. wood outdoor pavers are flat, thin forums designed to guard the outdoor cracks of your private home. they come in a selection of styles, from traditional shiplap to fashionable tongue and groove art. These woods may be made from unmarried woods, which include cedar, alright and pine, every supplying a unique aesthetic and purposeful characteristic
View higher quality, full size image (1011 X 756)
