Wall treatment / Lambrin
11/10/23
Craig Caughlan  Member
Website: https://www.instagram.com/craigcaughlan/
I would like some thoughts on one of my solutions for a wall treatment. I'm not sure what the architectural term in English is for what we call in Spanish a lambrin, a type of wall that lets light through.
Essentially what I have here is a 40" x 8' wall section consisting of 9 - 2.5"x10" vertical posts 8' long of American Walnut separated by 1.75" wide glass. The architect has other larger sections with larger posts and wider glass, but this is more complex.
It could be done in solid walnut with laminations, but I think an alternative solution is more economical with hopefully, less risk of failure.
The climate here in Mexico City is sub-tropical at 7,300' altitude. We don't have the temperature/humidity seasons in temperate zones.
The first image is what the architect wants. The second image is one of my solutions: moisture-resistant MDF bonded over a tube steel frame and veneered in 4mm thick by 5" walnut. Bonded with epoxy adhesive and finished in Milesi W/B.
Is there something I'm not seeing?
Lambrin.pdf
Lambrin___steel_tube.pdf
11/11/23       #2: Wall treatment / Lambrin ...
Fred Frehner
Hi Craig,
For this size of glass would it not be simply more efficient to just have one large 40" x 8' 6mm glass and than apply an inside and exterior frame kind of like a simulated divided lite?
Don't now how you have to connect to top bottom or sides that may influence it as well.
11/11/23       #3: Wall treatment / Lambrin ...
I would probably dado the ends and the posts would slide into 1" x 6" square tube mounted horizontally to floor and ceiling. The posts are rebated to provide a stop for the glass, which space is then filled with 5.5mm veneered MDF, and the interior edge of the post veneered. I've two other openings where the posts and spaces between them are larger (5.5" x 14.5"), but with this being more difficult for the size of the glass, I thought solving this would work for the other two. Fortunately, I just need to provide a parametric quote.
    Doucet Machinery
