Best Way To Mark Sheet Goods
1/2/24
Kyle Member
Website: https://www.vangarde.com/
What is the best way you have found to mark the edges of sheet goods? Plywood for example eats up felt tip markers. Is there a "best" type of marker for this? We mark the edges of the material upon arrival to indicate the project it is associated with so it is not used for any other project. We stack the sheets making the edge the only available real-estate to mark. Maybe there is another method for identifying the materials other than writing on the edges?
1/2/24       #2: Best Way To Mark Sheet Goods ...
Dave Edgerton  Member
What about a paint stick or the crayons used for marking steel?
Or maybe colour to colour code for each job?
1/3/24       #3: Best Way To Mark Sheet Goods ...
Print it out on a shipping label printer.
1/3/24       #4: Best Way To Mark Sheet Goods ...
Quicktrim
We buy milwaukee inksall markers in bulk on Amazon, less than 1.00 each .
They will last about 100 to 200 sheets per marker.
1/6/24       #5: Best Way To Mark Sheet Goods ...
What works best for me is to have a vertical rack for each cabinet, not that would work for large jobs
1/16/24       #6: Best Way To Mark Sheet Goods ...
Craig Caughlan  Member
Website: https://www.instagram.com/craigcaughlan/
Spray paint a 1" wide line down the stack; a different color for each project.
