Two sided melimine saw blade
6/21/16
John Bishop
We are doing more and more commercial work where the norm appears to be melamine boxes. We use a Putsch Meniconi panel saw for the majority of our cutting. It’s a 12foot vertical panel saw. Does a great job, it has a scoring unit but we typically do not use it.
What blades are folks using on a vertical panel saw without a scoring unit. I prefer to just swap the blades frequently we have had much better luck. As blades have improved so much I think the scoring units may very soon be a thing of the past.
I need a 250MM blade with a 30mm bore for cutting two sided melamine chip free. I’m sure you guys are using blades like that. Do you mind sharing that information with me?
D. John Bishop
Select Woodworking
Cincinnati, Ohio
6/21/16       #2: Two sided melimine saw blade ...
Kevin Jenness
Try a hollow ground blade. We had some Leitz blades with square top teeth alternating with trapezoidal ones with concave faces that were designed for that task. We rarely cut melamine but when sharp they did ok with veneer faced plywood. I think they would need to be sharpened frequently as the points are fragile. Scoring blades work well if kept adjusted.
7/29/24       #3: Two sided melimine saw blade ...
StateArtCab
Try a Forrest High ATB (alternate top bevel) blade, custom sized to your arbor and diameter. Plan B, get a Charles G. Schmidt 10" X 5/8" Bore - 80 Tooth Double Face Laminate Laser Cut Low Noise Plate ATB Grind, adapted to your arbor and/or diameter. I never use scoring and I have a hard time figuring out which side is the "good side".
