Unclamp Times For 5-Piece Doors
11/5/24
Troy Beverly
I just received delivery of a new Doucet small frame double door clamping machine. Been making doors with TB-1 and bar clamps for long time. My question is because I am trying to speed up the amount of doors I can fabricate, this machine can only hold 2 doors in clamp at a time unless I get multiple same size smaller doors and maybe I can double them up.
This being said I don't want to jeopardize my glue joints especially after painting and see visible Joints through he paint. I always use TB-1 and what is the minimum time before unclamping? I will still let the doors sit for 24 hours minimum before wide belt sander. I've seen pins in the back of the cope and stick but to me that isn't a substitution for clamp pressure. I was thinking maybe 30 minutes in the clamp then stick and stack for 24 hours. Any thoughts?
11/5/24       #2: Unclamp Times For 5-Piece Doors ...
I have a 5 station clamp. Average time back to the first set of clamps is about 15 minutes going at a leisurely pace.
I think if you took your time going between stations you'd be fine.
Maybe adjust the process up stream and cut a corner to slough that effort to assembly where it can chew up some time at there?
Maybe sand a panel and put that door together?
I think five(ish) minutes is adequate for titeblond original. It's enough to get it to tack.
Half an hour in the clamps means 4 doors an hour?
I think I'm thinking about that correctly?
I pin nail my doors. I just view it as a safety and little more holding of things until the glue goes full cure.
11/6/24       #3: Unclamp Times For 5-Piece Doors ...
Stuart
Experience has told me (over and over) that for doubt free glue-ups with TB1, stick with 30 minutes. I've had doors and panels spring back apart when cheating the clock if there was internal stress or moisture issues with material or ambient conditions. Pinning the joint helps, and I second the practice of setting overnight before working the faces through the sanding process. Shortcuts often burn you in the end. I'd rather be sure that everything is good, than have to rework even one door after the fact.
11/6/24       #4: Unclamp Times For 5-Piece Doors ...
I've been using TBII and have plenty of pipe clamps. Usually let them sit 45 minutes in the summer longer when the temps are closer to 63F. I really think if you have stress free joints you can do 15 minutes without worrying, 10 minutes is probably pushing it. I never pin my doors. I find that 3 days of rest is best to keep the joint from showing up. About the time it takes for the moisture absorbed from the glue into the wood to fully come out.
Usually make face frame inset doors so make the FFs first, then the doors and then fit them. Make the cabinets and then start sanding. By then the doors are worry free from any joint lines showing up.
11/9/24       #6: Unclamp Times For 5-Piece Doors ...
BH Davis  Member
Will your new machine allow for using a Workrite wood welder? TB2 and a quick zap and the joint is cured.
11/10/24       #7: Unclamp Times For 5-Piece Doors ...
Hen Bob Member
Try TB 50, tacks up faster than TB1. I also agree on letting them sit overnight
11/13/24       #8: Unclamp Times For 5-Piece Doors ...
Do some experiments.
Glue up a test joint with glue only, clamp for hours.
Glue up a test joint and pin the joint, remove the clamp immediately, let it dry for the same amount of time.
Destructively test the joint. Based on testing I did years ago the pinned joint is stronger. The added strength gives me enough reason to pin them. The added speed is a bonus.
Lots of ways to go on this one.
Good luck!
11/14/24       #9: Unclamp Times For 5-Piece Doors ...
Side note. Paneled ends, we clamp them tight and run pockets screws in. Usually alternating between a couple sets of clamps to give them a little more time.
That works really well, and likely massive overkill.
